dshall Posted September 1, 2017 Share Posted September 1, 2017 I cannot figure out What is square in ceiling? Can You? Here is link to plan https://www.dropbox.com/sh/yupg2amo2rv93e8/AADAh5pStycFDDcj6Jj7UVWRa?dl=0 Link to comment Share on other sites More sharing options...
Chopsaw Posted September 1, 2017 Share Posted September 1, 2017 That appears to be a Bloom patch. Turn off bloom or build a roof and it goes away. Sorry I could not give a better answer. You could call tech. Link to comment Share on other sites More sharing options...
dshall Posted September 1, 2017 Author Share Posted September 1, 2017 3 minutes ago, Chopsaw said: That appears to be a Bloom patch. Turn off bloom or build a roof and it goes away. Sorry I could not give a better answer. You could call tech. It wasn't the bloom. I think this is the first time I have seen this. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 1, 2017 Share Posted September 1, 2017 I see it all the time now, not sure what it is though, nothing above or below to cause it. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 1, 2017 Share Posted September 1, 2017 38 minutes ago, dshall said: It wasn't the bloom. Is that ever strange. I am sure that both of my suggestions worked the first time I tried but now I can't reproduce. It also did not show initially in Camera View Set and I went to All On Set but now that is not even working when I go back to Camera View it reappears. Super mysterious. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 1, 2017 Share Posted September 1, 2017 Those are caused by light sources (whether automatic or manual) and it seems to be more specifically tied to Point Lights. I don't have a perfect answer to the problem, but you can try moving the lights and/or the camera to get them to disappear. Link to comment Share on other sites More sharing options...
Anne_S Posted September 6, 2017 Share Posted September 6, 2017 Hi All, A square shadow in the middle of a room's ceiling is a known issue that is associated with the default interior light. If you add an actual light source (fixture or Added Light), it should go away. I know that our software developers are aware of this problem but make sure they've seen this thread, too. The squares on the walls and floors, however, are another matter. We haven't seen those before, so if you have a plan in which they are a problem, PLEASE send them to Technical Support using the Online Support Center at https://support.chiefarchitect.com. Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 6, 2017 Share Posted September 6, 2017 37 minutes ago, Anne_S said: Hi All, A square shadow in the middle of a room's ceiling is a known issue that is associated with the default interior light. If you add an actual light source (fixture or Added Light), it should go away. I know that our software developers are aware of this problem but make sure they've seen this thread, too. The squares on the walls and floors, however, are another matter. We haven't seen those before, so if you have a plan in which they are a problem, PLEASE send them to Technical Support using the Online Support Center at https://support.chiefarchitect.com. Thanks! I guess I'll do us all a favor send this in, but as I said before, those are caused by light sources in general and not just the default interior light. Was able to very quickly and easily reproduce in the plan Scott attached. The problem seems to be most prevalent when the light source is placed relatively close to an adjacent surface... Light boxes.zip Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 6, 2017 Share Posted September 6, 2017 I SEE THEM WITHOUT ANY LIGHTS IN THE PLAN. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 6, 2017 Share Posted September 6, 2017 2 minutes ago, DRAWZILLA said: I SEE THEM WITHOUT ANY LIGHTS IN THE PLAN. You are probably seeing a lot more now without your dark glasses but is it a single square shadow like in Scott's plan file or all over like Michael and Eric have posted. As Anne said the single one can be attributed to the default light, but if you are seeing more you may need to also send in a plan file. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 6, 2017 Share Posted September 6, 2017 9 minutes ago, DRAWZILLA said: I SEE THEM WITHOUT ANY LIGHTS IN THE PLAN. I don't actually think that is possible Perry. Rooms automatically get a default light source whether you want it or not. Ironically, the only way I know to turn it off is to manually add another light source and then turn THAT light off. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 6, 2017 Share Posted September 6, 2017 I JUST ROTATE THE 3D VIEW UNTIL I DON'T SEE IT, BUT ITS POSIBLE WHEN I SAID NO ELECTRICAL I MEAN JUST ANYTHING FROM THE LIB. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 6, 2017 Share Posted September 6, 2017 Perry is that with the Sun follows camera setting ? I can make that do some pretty crazy stuff with and interior shot and a manually placed light that is turned off like Michael said. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 6, 2017 Share Posted September 6, 2017 sun follows camera is always on for me. I have no lights in this plan yet. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 6, 2017 Share Posted September 6, 2017 11 minutes ago, DRAWZILLA said: sun follows camera is always on for me. I have no lights in this plan yet. Not really sure if that is a bug or just something the software was never intended to do. Link to comment Share on other sites More sharing options...
Anne_S Posted September 6, 2017 Share Posted September 6, 2017 Hi All, Thanks for the additional information. I am not sure if the ceiling shadow associated with the default interior light is the same problem as the one associated with point lights, but it certainly could be. I spoke to one of our software engineers, though, and learned that although they aren't "real objects", Added Lights do have a bounding box of some kind, and the surfaces of that box are capable of casting shadows when they interact with the surface of an actual object - basically, it's a type of Z fighting. It looks like you can avoid that problem if the Added Light in question is about 40" or more away from any surfaces. I hope that helps - and thank you again for the additional details. Link to comment Share on other sites More sharing options...
CharlesVolz Posted September 7, 2017 Share Posted September 7, 2017 The attached screen shots show: 1. the default lighting that Chief uses to light the scene if the user has not added lighting. 2, 3 & 4. the same lighting with the camera moved slightly. You see the bounding box which can z-fight. 5. after adding lights. Chief's default light is not used. 1 Link to comment Share on other sites More sharing options...
